Quick connect on slave trouble
I just replaced the transmission in my 99 c5.
Everything was going ok, untill Im trying to bleed the clutch and the Hydraulic quick connect pops off.
I can NOT for the life of me get this to reconnect. Its in a tight spot on a c5 and im not sure what to do.. I hope I can do something without pulling the torque tube again.
It appears the small prongs within the connector are bent slightly. I tried to bend them back but it didnt help. Not sure what to do at this point..
Is there anyway I can buy or rent a tool to cut the line and put a coupler on the Stainless braided line. Screw this "quick" connect.
I need some help
I need some help
I got it connected just for follow up incase anyone searches.
Inside the female end of the quick connect the little metal retainer ring inside, The prongs that come up to lock the connector 2 were bent over. I took a small screwdriver and straightened them, Cracked the Slave bleeder, Pushed the plunger in on the Male end to relieve pressure and It went right in.
