Stupid quick question
Old 04-01-2010, 10:54 AM
my95LTwon's Avatar
Default Stupid quick question
I just filled the trans fluid in my 94 m6. I just filled it through the fill/check hole until some came out and let it drip until no more would come out. Now my question is, should I lower it off of the jack stands and let it drain more, or is it full when it stops dripping while it is still raised up? I guess it would have to be while it is still raised up because how else could you check it with your finger unless it is jacked up? I'm just not 100% sure, thanks for schoolin this noob lol
Old 04-01-2010, 01:24 PM
85MikeTPI's Avatar
Unless you had a lot of rake in your jack stands, it should be fine..
