Clutch Slipping
Clutch Slipping
I think my clutch is slipping. Revs up at high rpm under boost (Twin turbos) . Just installed a new flywheel , pressure plate and clutch about 3 months ago. Took it easy to break in. What should I be looking for to fix it? ( pressure plate to loose, tight, ect...)Runs fine until throttle is wide open and it hits about 5 psi of boost.I have a F1 STAGE 2 CLUTCH KIT& FLYWHEEL
