Alternate LS7 pressure plates?
Guys I've had nothing but problems with my LS7 clutch for a while now. I've gone though 2 master cylinders and 2 slave cylinders chasing the problem. I have concluded I have a defective pressure plate. I do like the way the ls7 disc drives and would like to keep it. I'm running the LS7 clutch with LS2 flywheel, what options do I have for a better pressure plate?
So is there another pressure plate available for the LS7 disc or not?
I haven't seen a non SAC LS7 style pressure plate. I bought the SPEC LS7 SAC pressure plate and ran into the same problems I had with the stock LS7 pressure plate. That is, sticky pedal. I'm sick of the problems so I am going to a twin. Just bought a used Exedy twin off ebay. Hopefully once I get it cleaned up and rebuilt, my problems will be gone.
I just wanted to update this. After a few weeks of daily driving and about 300 miles of freeway driving the SAC pressure plate must have readjusted itself. I had the cruise set @ 70 mph for about 100 miles and as soon as I took my exit I noticed my pedal had stiffened up a little. I have not really tried to shift at high rpm for a while since I knew I would be pulling the clutch. Well I tried banging the gears and the car shifts like it did when I first installed the clutch. Seems to be working great now, but I bet when I go to the track it will not shift haha
