Switching over from auto
Old 05-02-2010, 03:36 PM
z28_YOU_HO's Avatar
Default Switching over from auto
Im thinking of switching over from my auto to a T56..Where is a good place to pick one up new?? Im willing to buy used but would prefer to have a new trans with a warranty..
Also what all will be needed?? Will i need to get a new ECU?
Old 05-02-2010, 03:40 PM
z28_YOU_HO's Avatar
actually just found this..dunno if anyone on here has a used t56 for sale???
Originally Posted by dragonZ28
OK. Here is a parts list needed for swapping out a 4L60E for a T56 in an LS1 Fbody:
master + slave cylinders (prefer 01 up) (also, master cylinder u-bolt and nuts)
new pedal assembly with clips for clutch rod and brake rod
new console tray with shift boot, and lower shift boot
pilot bearing, bellhousing, T56, crossmember, T56 torque arm mount and bolts, shifter
pressure plate, flywheel, clutch, and all related bolts and clutch tool
You will need to have your PCM flashed to a 6spd PCM, but you do not need a new PCM
THE SAME DRIVESHAFT CAN BE USED
REWIRING instructions: (disconnect battery)
connect the orange w/ black stripe and the black wires directly together for the hatch release to work.
connect the purple w/ white stripe and the dark green to the clutch switch on the manual pedal assembly so the clutch pedal needs to be depressed before the car will start. Polarization does matter here. I forget which wire goes to each connector, but trial and error will solve this in 2 seconds. (do it right, use solder and heat shrink tubing).
connect light green and brown into the reverse switch located on the passenger side of the T56 for the reverse lights to work. You can buy the pigtail, or engineer a way to get the wires to hold and be protected. I put the wires in and pinched them into place. The pigtail will run about $50 of unneccesary spending. Polarization does not matter. (again, use solder and heat shrink when you add wire to these).
Also, the VSS (vehicle speed sensor) will need to be cut, and elongated by soldering on about 6 inches of extra wire to each wire going into the connector. This VSS will plug directly into the VSS port on the drivers side of the T56 by the shifter.
WATCH THE FOLLOWING FUSES: starter, gauges, Turn/BU lights.
Troublesome parts:
The hardest part is mounting the master cylinder. Pulling the auto is no big deal. You will need a long extension or two, and a swivel joint to get this thing out though.
The steering column will need to come out, but it is pretty simple. 6 bolts hold it in. 1 is under the hood at the joint in the column, 3 are on the firewall behind the pedals, and two are holding it to the underside of the dash. Afetr these are removed and all electrical connectors are unplugged, wiggle it out of there. It should be free of any connections at this point, except the safety device on the top of the column. Follow the device that hooked to your auto shifter up to your column. Take this off. I believe it has 2 screws holding it in place. This locks the ignition until the car is in park. Since you no longer have "park", this thing needs to go.
Everything else can be found in the LT1 instructions above. They are almost exactly the same, except the wiring instructions. If you have any questions, send me a PM here, or our local message board www.kyhorsepower.com if I haven't responded in a timely manner. (sorry MIGHTYMOUSE )
This whole conversion costed me only $2300. This can be done in a garage with jackstands and intelligence. Don't be stupid and attempt heavy lifting or dropping without help by your side.
