Help clutch pedal on floor
Old 05-17-2010, 10:57 AM
427LS7HCI's Avatar
Default Help clutch pedal on floor
I just purchased a brand new master & slave and installed it. A buddy of mine and myself then bled the system and the clutch pedal is still on the floor. What could we have been done wrong? We tried bleeding it by popping the clutch pedal up and stomping the clutch pedal to the floor a few times as well as regularly pumping the clutch pedal. The clutch pedal just sits on the floor and when I pop it up and touch the pedal it just falls to the floor. That part is a new OEM master and new OEM slave. The clutch is engaged but will not disengage.
Old 05-17-2010, 09:05 PM
Wesmanw02's Avatar
Sounds like you still have air in the system.
Did you bench bleed the master and line assembly?? If not, it can take a long time to work all the air pockets out of the system. Just keep bleeding, the pedal should start to come back up!!
Old 05-18-2010, 09:06 AM
427LS7HCI's Avatar
thanks. we will keep bleeding it
