Best sealant for T56?
I'm wrapping up a rebuild, and was going to use black RTV but the stuff I scraped off was a red glue looking kinda stuff.
Suggestions on what to use? This would obviously be the bellhousing to case, and case to tailshaft sections.
I use ultra black sealant as well and it works great. That red stuff is commonly used on new Tremec TKO series 5 speeds. I forget what its called but its kind of messy to clean off when doing rebuilds.
Thats anaerobic sealant, which I hate as well. I use ultra black, ultra blue, and sometimes high temp red. Never use ultra gray, as you will just about have to break the case to get it back apart.
Permatex® High-Temp Red RTV Silicone Gasket
OEM specified. Formulated for hi-temp applications, or heavy-duty use (such as towing, etc.). Replaces almost any cut gasket by making reliable “formed-in-place” gaskets that resist cracking, shrinking and migrating caused by thermal cycling. Coats pre-cut gaskets to increase reliability. Temperature range -65ºF to 650ºF (-54°C to 343°C) intermittent; resists auto and shop fluids. First generation 1970-1980 gasket maker.
Suggested Applications: Valve covers, oil pans, timing covers, water pumps, thermostat housings, transmission pans
Permatex® Sensor-Safe Blue RTV Silicone Gasket Maker
The original Permatex Blue. Will not foul oxygen sensors. Replaces almost any cut gasket. Makes reliable “formed-in-place” gaskets that resist cracking, shrinking and migrating. Coats pre-cut gaskets to increase reliability. Temperature range -65°F to 500°F (-54°C to 260°C) intermittent; resists auto and shop fluids. First generation 1970-1980 gasket maker.
Permatex® Sensor-Safe High-Temp RTV Silicone Gasket
Formulated for oxygen sensor equipped engines. First generation 1970-1980 gasket maker. Temperature range of -65°F to 650°F (-54°C to 343°C) intermittent; resists auto and shop fluids.
Permatex® the Right Stuff® Gasket Maker
Return equipment to service immediately when you make leak-proof gaskets in just one minute with the Right Stuff.® This latest elastomeric rubber gasket technology is blowout resistant and outperforms pre-cut gaskets. Specified on production lines by GM, Ford, DaimlerChrysler and Mercedes-Benz. Temperature range -75°F to 450°F (-59°C to 232°C) continuous, 500°F (260°C) intermittent.; resists ATF, coolant, oil and other shop fluids. Protects against leaks caused by vibration and thermal expansion. Sensor-safe.
Suggested Applications: Automotive and marine gaskets, valve covers, gearbox covers, pumps, compressors, oil pans, thermostat housings, water pumps
Permatex® Ultra Black® Maximum Oil Resistance RTV Silicone Gasket Maker
OEM specified. For dealership warranty requirements, ensures extended drivetrain warranty compliance. Fast-curing formula. Sensor safe, low odor, noncorrosive. Meets performance specs of OE silicone gaskets. Retains high flexibility, oil resistance properties through use of a patented adhesion system. Temperature range -65ºF to 500ºF (-54°C to 260°C) intermittent; resists auto and shop fluids and vibration.
Suggested Applications: Valve covers, oil pans, intake manifold end seals, timing covers, transmission pans
Permatex® Ultra Blue® Multipurpose RTV Silicone Gasket Maker
OEM specified. Permatex® Ultra silicones were developed to meet today’s technology changes. Sensor-safe, low odor, noncorrosive. Outstanding oil resistance and joint movement values. Eight times more flexible than cork/composite gaskets; three times more oil resistant than conventional silicones. Temperature range -65ºF to 500ºF (-54°C to 260°C) intermittent; resists auto and shop fluids and vibration.
Suggested Applications: Valve covers, oil pans, timing covers, transmission pans, differential covers
Permatex® Ultra Copper® Maximum Temperature RTV Silicone Gasket Maker
OEM specified. Highest operating temperatures for 4-cylinder, turbocharged or high-performance engines. The most advanced, high temp RTV silicone gasket available. Sensor-safe, low odor, noncorrosive. Superior adhesion. Three times more oil resistant than conventional silicones; eight times more flexible than cut gaskets. Temperature range -75°F to 700°F (-59°C to 371°C) intermittent; resists auto and shop fluids and vibration.
Suggested Applications: Exhaust manifolds/ headers, valve covers, oil pans, timing covers, water pumps, thermostat housings
Permatex® Ultra Grey® Rigid High-Torque RTV Silicone Gasket Maker
OEM specified. Designed specially for high-torque and high vibration applications, like those common in import engines, this premium RTV gasket maker exceeds manufacturers' performance requirements. Noncorrosive and low-odor. Maximum vibration resistance, with outstanding resistance to oils, cooling and shop fluids. Guaranteed not to leak. Temperature range -65ºF to 500ºF (-54°C to 260°C) intermittent.
Suggested Applications: Valve covers, oil pans, intake manifold end seals, timing covers, water pumps, thermostat housings
Permatex® Water Pump & Thermostat RTV Silicone Gasket
A noncorrosive, sensor-safe RTV silicone gasket material formulated specifically for water pumps and thermostat housings. Highest water-glycol resistance available in an RTV silicone. Temperature range of -65°F to 500°F (-54°C to 260°C) intermittent.
