NAPA/Perfection Slave Cylinder, new style fitting?
I'm getting ready to replace the slave cylinder so I ordered this from NAPA. It's made by Perfection. It has a new style connection for the clutch line compared to the last GM one I did. Anyone use this before? Good/Bad?
I installed one today with my t56 swap. I have to figure out some clutch engagement issues (most likely in no way related to this slave) and then I'll comment.
as far as installation, it bolts up fine. it's sort of a pain to remove the line from it while it's installed if you don't have a snap ring pliers since the clip sits in the bellhousing opening, but no complaints. I also installed PERFECTION's clutch/pressure plate/pilot bearing. They're owned/run by the same people as ZOOM so they should be good quality.
