Tick Adj. Master Cylinder, stripped rod?
rod came unattached from the pedal and doesn't want to reattach. Disconnected it from the firewall and tried to screw onto the pedal from a better angle and still no luck. Looks like maybe first threads are stripped?
LS1TECH Sponsor
If you're having a technical problem with a kit of ours, shoot our technical department an email and they'll quickly help you out: http://www.tick-performance.com/tech/
