Trans whine on decel
Old 08-15-2010, 10:44 AM
Shamson5.7's Avatar
Default Trans whine on decel
Did a search but most seem to be able trans whine on acceleration.
Pretty much any gear I have it in the tranny whines when I let off of the gas. Goes away completely when Im accelerating or when the clutch is pressed in or it's in nuetral.
Any ideas?
Old 08-15-2010, 11:46 AM
crainholio's Avatar
Are you positive it's the trans and not the rear diff?
I've seen whiny T56 boxes quiet down when the fluid is changed to Synchromesh (GM or Pennzoil), but your description sounds more like the rear differential.
Old 08-15-2010, 11:59 AM
Shamson5.7's Avatar
Hmm What would cause the rear to just start whining all of a sudden? I just had the seal replaced about a year ago w new fluid. The 12bolt has run fantastic for the last 4 years w.o any noise.
Old 08-15-2010, 02:14 PM
Shamson5.7's Avatar
And the sound seems to be coming from where the transmission is, right under the dash and not near the back of the car.
Old 08-15-2010, 02:57 PM
crainholio's Avatar
I'd change the fluid in the trans, probably something on the thick side like Amsoil ATD or Pennzoil Synchromesh.
Old 08-15-2010, 05:21 PM
94lt105's Avatar
Change Fluid and check the u-joints! Those would be my first two things to look at!
Vince
Old 08-15-2010, 05:58 PM
thesource's Avatar
Sounds like the diff to me. Does it make the same noise in 4th gear?
Old 08-15-2010, 09:17 PM
Shamson5.7's Avatar
It makes the noise in all gears when I let off the gas. More prominent in 5th and 6th.
Old 08-16-2010, 12:03 AM
JustAGoat's Avatar
I seen this in a post like 3 years ago hope it helps...
http://www.differentials.com/diagnose.html
Old 08-31-2010, 06:10 PM
Shamson5.7's Avatar
Turns out I had a bad pinion seal which is why it was leaking and upon tearing it apart I had a bad pinion bearing as well which caused the howling I heard.
Quick Reply: Trans whine on decel
