LT1 T56 flywheel question
Old 08-21-2010, 01:09 AM
Rob94hawk's Avatar
Default LT1 T56 flywheel question
Just pulled my engine the other day and this is what my clutch looks like after sitting for 10+ years:
1. Do you think I could get away with resurfacing the flywheel and then buying a stock or aftermarket pressure plate and disk?
2. What's the stock clutch torque rating? Doing an LE2 heads/cam upgrade
I appreciate any advise you can give me. Thanx
Rob
Old 08-21-2010, 02:20 AM
BlackBird87's Avatar
I would def resurface the flywheel. Its been my understanding that 95% of the pp you buy are pretty much the same and the difference is in the disc so in theory you can buy a stock replacement kit from autozone (159) and then buy a nice disc (mcleod) so for around 300 you should have a clutch to hold the power. Also check out this thread seems like a good deal https://ls1tech.com/forums/lt1-lt4-m...-its-here.html
Old 08-21-2010, 09:06 PM
Rob94hawk's Avatar
Other than the slight rust, the disk doesn't look too bad. I'll see what happens with the flywheel first. If it's able to be resurfaced then I might go with just a new stock pressure plate. We'll see.
Old 08-21-2010, 11:32 PM
Spartan7's Avatar
Machine shop should be able to resurface the flywheel no problem. I had one resurfaced that looked worse than that.
The only problem I see with buying the parts store PP is that most of them are made in China now.
Old 08-22-2010, 12:57 AM
jmd
jmd's Avatar
A new PP will be the second design so while it's apart you may as well go new on the clutch parts.
Yes, resurface the flywheel (or check pricing on Autozone; without core, they were < $100 last I looked)
Old 08-30-2010, 08:50 PM
Rob94hawk's Avatar
Got the flywheel resurfaced. One less thing I have to worry about:
Quick Reply: LT1 T56 flywheel question
