Bleeding with a mighty vac??
I looked over the tutorial and was a little confused on what to do if its pulling the fluid out when you stick the nozzle in the hole wont you have to stop like every 2 seconds to replace the fluid? if any one could clarify that steps that would be awsome
It shouldn't pull really any fluid. It will create suction and the fluid will come up the tube maybe half an inch. You will then start to see bubbles come out of the fluid that is visible in the tube. If it's pulling fluid it will do it out of the reservoir and you are doing it wrong. You need to make sure to have the correct tip on so it fits inside the hole at the bottom a little.
