installing spec stage 3 clutch
Old 09-03-2010, 06:44 PM
ls1curt's Avatar
Default installing spec stage 3 clutch
im in the middle of installing a spec stage 3 clutch in my 2001 ls1 camaro. i have about 1/16 inch of space between my measurements b and a without any shims. does that sound right/is it a good distance between?
Old 09-03-2010, 08:12 PM
raven154's Avatar
That should be fine. That is gap and not over lap right?
Old 09-04-2010, 07:20 AM
ls1curt's Avatar
correct, its about 1/16 between them
Old 09-04-2010, 12:00 PM
raven154's Avatar
Then as long as your measurements are spot on, thats fine. Could even be a little more but my caddy was pretty close too. Engagement will most likely be more toward the middle to upper half of the throw.
