SBC vs LS1 clutch compatibility
Old 09-28-2010, 01:43 PM
serpentnoir's Avatar
Default SBC vs LS1 clutch compatibility
quick question:
Will a SBC pressure plate bolt up to a LS1 flywheel? Is the bolt pattern different?
Old 09-28-2010, 08:22 PM
jmd
jmd's Avatar
The 10.5" clutch disc compatible pressure plates are different bolt pattern than an LS_ pp blt pattern.
I've never compared the larger clutch pp's to the LS_ pp's.
Old 09-29-2010, 09:25 AM
SPEC-01's Avatar
The bolt pattern for the stock 11" SBC plate will match the LS1 flywheel. There may be a difference in dowel-pins location and or presence but that can be taken care of easily. Check your stack height and bearing depth as well to insure that you have the proper geometry.
Old 06-15-2012, 11:34 PM
badazz81z28's Avatar
I had the same question. I do remember the Centerforce pressure plate I used had multiple holes for mounting. I want to use it if I can for my LS swap. It would save me a few $$s/
Quick Reply: SBC vs LS1 clutch compatibility
