Master quick disconnect wont go back in slave
I have had my 01 WS6 clutch assembly apart 4 times now and with no problems except for the 1st time it took an hour to figure out how to disconnect the line from the slave. This time I pulled my master out to do the drill mod, all went well, smooth sailing and once I was down to plugging the line back into the slave and bleeding the system I hit a road block lol. I have done about everything to this car myself, new gears,tranny,clutch, all but engine install, and I struggle for 3 hours to push the fitting back into the slave cyl, and still did not get it in! I never had a problem when connecting the disconnect, slave is just a year old, can the metal ring in the slave fitting be bent or something? I even took the plastic ring off that is used to disconnect the line and tried pushing it in that was and I even have the floor board hole cut out to bleed my clutch when I first got the car 2 years ago. I am about to explode from frustration!
yep
Yea I tried cracking the bleeder, pushing pedal to the floor, everything but leaving the cap off the master cylinder, it has no fluid in it now, and the quick disconnect fitting end will push in with no problem to drain fluid out, so only thing I cant think of is the metal ring inside the slave female connector maybe has finger bent down too far maybe and just isnt letting the master side snap in. I might try changing it out and put the old slave metal snap ring in the female fitting.
blown master.
When I finished the drill mod and flushed the line out from the bottom to the top when the line was out of the master cylinder to flush out metal shavings, but also on installuniversity.com it said after you hook the line back to the master cylinder either bench bleed it or hook it all up and bleed it to remove old fluid from master by pressing down the clutch pedal while keeping the end of the line pressed in so fluid would flush through. The pedal wont press down unless the line is hooked up to the slave or you have the end of the line depressed in with something to let pressure through. I think you were thinking that I tried pressing the pedal down without the line being depressed or like you said not hooked up to the slave. The line snapped in fine when I took the O-ring off the end of the quick disconnect, so I know its not the metal ring in the fitting. Could the O-ring have heated up too much and swelled up too much, I dont remember it ever needing to be pressed in so hard to get it connected....with the o-ring on its about 1/16in from snapping in, I just cant get enough leverage with my fingertips to get that last 1/16in.
Sometimes they're just stubborn. I've removed mine a few times and sometimes it clicks in easy and other times it's like it's crooked. Pull the quick connect back out and as dumb as it may sound make sure it goes in as straight as possible and add a slight twist to it. This has also worked when I was about to just pull my hair out. Also, one time I got so frustrated I just let it sit overnight and the next day it slid in smooth as silk.
same thing happened to me
