Need help identifying this part
I have a 94z28 with the lt1.. t56 from a 95 z28 going in.. pulled the tail shaft off of it to take a peak at the reverse gear as it was having trouble going into reverse but now wont go hardly at all unless you have the car off.. here is what i found in the bottom.. im assuming this is prob. part of the reverse synchro.. how do i replace these items..
btw there was one of each piece.. posting 4 pics to hopefully get good coverage of the offending articles.. lol
you need 3 keys (the small stamped piece,) the key retainer plate (used because reverse does not have an opposing gear) and a spring (your square cut wire piece.)
If the slider has good teeth, you can reverse the synchro so they are used for reverse, putting the worn teeth out of action.
I have some of those parts I can sell you if you're wanting. I have the springs, keys, **** i have a whole assembly used.
Only reason they're not in my tranny is because the kit I used to rebuild it came with brand new parts
And to replace them will be simple. Pull the tranny, pull the tail shaft off and i believe you have the speed sensor and some snap rings and possibly a fork. The syncro assembly should slide off. There will be bearing full of needle bearings under one of the gears. It's easy. Put everything back on exactly how you took it off.
