Tick Performance Master In Finally...
Old 11-01-2010, 05:30 PM
LSWNDR's Avatar
Default Tick Performance Master In Finally...
So i'm not sure how to look at things just yet only had the car back on the road for about a week an i'm thinking the pedal needs some more adjustment it's about a quarter of an inch above the brake pedal an is still letting out kinda low, but i don't want to put it up to high because my knee hits the steering wheel... I'm having catching issues guess it needs to be adjusted a little bit more...
Old 11-01-2010, 05:31 PM
LSWNDR's Avatar
What fluid is everyone running in the mastercylinder for this unit?
Old 11-01-2010, 06:56 PM
RedRallyeZ's Avatar
im just running DOT 4, i think mabye prestone brand.
Old 11-01-2010, 09:50 PM
therealcreeper's Avatar
adjust it as tick recommends and leave it alone
Old 11-02-2010, 08:10 PM
~BuMps AloT~'s Avatar
I use a synthetic DOT 4
Old 11-03-2010, 08:56 AM
LS1TECH Sponsor
Joey@Tick's Avatar
Make sure you adjust our kit the way it needs to be adjusted (by following your instructions), not the way you want it. This is very important!
Thank you for your business BTW - we suggest DOT3 fluid in the kit.
