Changed hydraulics, now I can't get into gear
Old 11-09-2010, 08:35 PM
Counted Out's Avatar
Default Changed hydraulics, now I can't get into gear
So after I did a clutch swap, I wasn't able to get into reverse so I replaced my master and slave with a prebled GM unit. After the swap, I'm not able to get the car into any gear. It will go into gear with the car off though.
What could have gone wrong?
P.S. - I thought it was a clutch problem, so I replaced the new disc and pressure plate for a second time and the problem is still occurring.
Old 11-09-2010, 09:19 PM
SWEET98SS's Avatar
Does it go into gear with the car off?
Old 11-09-2010, 09:22 PM
ozzman98's Avatar
did u do anything to the fly wheel? did u get all the air out of the line?
Old 11-09-2010, 09:25 PM
GT-OH's Avatar
This!
Old 11-09-2010, 09:45 PM
SWEET98SS's Avatar
He said it was prebled. I say it needs a shim or adjustable master. But if it doesnt go into gear with the car off then thats not the problem.
Old 11-09-2010, 10:24 PM
Yeah, it easily shifts while off.
Flywheel was resurfaced. No air in the system.
For the most part, LT1's don't need an adjustable master cylinder - especially with the two types of clutches I've used (Ram and Competition).
Old 11-10-2010, 06:28 AM
SWEET98SS's Avatar
If it goes into gear easily with the car off and doesnt go into gear with the car on, the clutch is not releasing all the way. You either need an adjustable master or a shim.
