LT1 Clutch Measurement Request
Old 11-23-2010, 12:33 AM
Foxman267's Avatar
Default LT1 Clutch Measurement Request
LT1 T56 clutch: Im looking for the distance between the crank mating surface and the tips of the fingers when installed.
I hope you guys can help... And I hope the drawing helps
Old 11-23-2010, 10:28 AM
jmd
jmd's Avatar
I don't have a loose flywheel to help. What's the adaptation goal?
Old 11-24-2010, 01:33 AM
Foxman267's Avatar
The goal is bolting up a Toyota 2JZGTE to the T56. There's a 1/2" thick adapter plate involved which when combined with a different crank flange depth, clutch assembly thickness, and different style throwout bearing, I expect there to be some fabricating involved in hooking up the clutch fork in order to keep the factory geometry.
Come to think of it... All I need the distance from the back of the block to where the fork pulls on the throwout bearing.
Old 11-28-2010, 12:50 PM
Foxman267's Avatar
Bump?
