Need advise removing clutch pedal/master
Old 12-13-2010, 11:43 AM
Vetal's Avatar
Default Need advise removing clutch pedal/master
I am taking my manual setup off and now I don't know how should I take off clutch pedal and it's cylinder, and also where do I disconnect the clutch hydraulic line?
Thank you!
Old 12-13-2010, 12:33 PM
99FormulaM6r's Avatar
Search for TheBlueKnight. He has a video that shows u how. I would, but I'm on my Phone.
Old 12-13-2010, 05:54 PM
Vetal's Avatar
I will, thanks! Meanwhile, any written description? Is it hard to take off clutch pedal? Where and how do I disconnect the clutch line?
edit: found the video. He disconnects the line at the slave (in the gearbox), seems there are some clips holding the fitting, but I don't see any on mine.
Regarding master, do you have to just pry the rod off the pedal assembly? Then I wouldn't even have to disconnect the line, if it comes out into the engine bay...
Old 12-14-2010, 01:11 PM
Vetal's Avatar
I've unbolted 2 nuts holding master to the firewall but cannot push it far enough into engine bay. Should I just keep pushing and punching on the bolts from the inside or do i have to loosen or remove brake cylinder??
edit: few punches sorted it out.
Old 12-14-2010, 05:50 PM
djfury05's Avatar
The line to the slave has a "quick disconnect fitting" on it. There should be a small white plastic piece on the end of the fitting that you push in towards the slave and it will come disconnected. Its like a fuel like disconnect tool basically but for the slave line.
