Gears swaps on ctsv-Fbody t5-6
Old 01-16-2011, 08:46 PM
underdog51's Avatar
Default Gears swaps on ctsv-Fbody t5-6
I want to swap 1st and 2nd gear between my two t56s. Is there going to be a compatibility issue between my fbody t56 and the ctsv t56 with these gears? thanks for any leads
scott
Old 01-17-2011, 08:11 AM
85MikeTPI's Avatar
You can't split gears between sets because of the single cluster countershaft. Also, the double/single cone synchros&gears of the Fbody are not compatible with the triple/double cones in the late model GM T56s. If you want, you can swap over the CTSv to a MM6 gearset from a C5 corvette, but all the ratios will be MM6. You'll also have to lose the dual-mass flywheel if you haven't already.
Old 01-17-2011, 07:50 PM
underdog51's Avatar
thanks for the info
Old 01-21-2011, 09:54 PM
haighter's Avatar
Also the main shafts are different from the M6 and the M12 for the CTS-V to a F-Body trans.
Quick Reply: Gears swaps on ctsv-Fbody t5-6
