Bolt Size
Bolt Size
There are 6 bolts holding the bell housing on. On the bottom corners there is one, one on each of the top corners, one in the top middle and one just right of that. The ones on the top are M10-1.5 bolts. Can somebody tell me what the bottom ones on each corner are? I've tried M12-1.75 and they don't work, the M10-1.5's are too small. Does anybody know? Please help.
They are all the same size 10x1.5
The bottom ones are bad about getting stripped out, so that's gotta be your problem. You're going to need to drill the holes and and heli-coil them abck to the original size.
