Thoughts on using Anaerobic Sealer / Gasket Maker on a t56 ?
Just was thinking what the general thoughts were from the guys who build these everyday.
I was getting ready to put mine together and I saw my stock pile sitting there and was thinking Man I have a lot of that... I know it will work. I used it on most of the T-5s I rebuilt and upgraded , front diffs I rebuilt of course since that's what GM recommends .
I know its some very good stuff that is recommended for these type of sealing surfaces. So just out of curiosity what do the "experts" say? why don't I see these rebuilt and upgraded units using this stuff?
Is it too messy since it takes forever to really dry? or is it because of the cost RTV does a fine job for less?
I plan to use it as well since I know it will work and is a great sealer to use for these but I was wondering why I don't see the re-builders using it. only thing I'm thinking is cost and if you use too much it gets very messy.. but the nice thing is that stuff wont find its way into bearings like RTV can and well DOES
The joint needs to be designed for the sealer. The flanges can be smaller/ narrower with anaerobic but the fasteners are spaced closer together and generally smaller. RTV is cheaper. The best sealer for a T56 is RTV because the joint/ flange was designed for it.
Just my thoughts would to use the gray general motors sealant (gms). That red stuff your talking about is the reason way northstar halfblocks always leaked and front diffs on c/k trucks. If i remember right gms is now what the northstars call for since that anaerobic stuff failed. Just a thought. I looked threw gm service doc's and alldata neither showed anything specs for sealant in a t56.
here was a tread i remember about this subject.
https://ls1tech.com/forums/manual-tr...alant-t56.html
DO NOT use anaerobic!!! Every time I tear down a tranny with this type of sealant, I want to punch the person in the face who put it on there. It's a major pain in the *** to clean off. It hardens in the absence of oxygen, so it has this hard plastic-like consistency.
Also, any type of Ultra Gray or any hard RTV like that is not good to use. It might work great on a motor, etc... but it will make it nearly impossible to get the tailshaft housing off later on down the road. Just about any other type of RTV works fine and comes apart/cleans up easily when the tranny has to be opened up again.
The Tremec 3550/TKO 5-speed trannys all come from the factory with anaerobic, and that is what Tremec calls for on these particular trannys. Every one of these that I have done has been a real pain to clean off. I usually have to use a razor blade to get under it and scrape off. Then I go back over it with a wire brush wheel on a die grinder. It takes about 5x longer to clean off.
When I go back together with these trannys, I just use regular RTV (ultra black or ultra blue) and it works fine. The only reason that I can think of for using anaerobic from the factory is that the case pieces can sit out for a very long time before they are assembled, since it cures only with the absence of oxygen. So most likely, it makes the assembly process easier or quicker at the factory. I've talked about this with other transmission builders, and we generally agree on this subject.
