M6 shiftting problems?
Alright heres the deal I have a Ls7 clutch with bout 8k miles on it, i just started having problems shifting at high rpm 5500-63 1st to 2nd not bad but 2nd-3rd wont go in gear and then feels like pedal is sticking to floor. I replaced all Hydraulics, Synthetic dot 4 fluid, clutch master and slave and i did drill mod. Still i have a problem transmission doesnt grind in any gear, around town driving is is fine, very seldom if i dont put it in 3rd gear all the way it will kick out of gear? Im not really sure what else to do from here? I was reading another post is it possible syncros are Bad?
I started having similar M6 symptoms. When I shift mainly in gears 1 through 3 it just feels really notchy not as smooth as it should be. Then 3rd I have to really make sure its up in there or it has poped out a couple times
