Clutch help
Old 02-14-2011, 05:46 PM
mach1's Avatar
Default Clutch help
Does anyone here know about building a clutch? I am changing out the disc in my clutch and the new disc is .060" thicker, I need to find out the correct way to check the diaphragm preload on the pressure plate.
Old 02-17-2011, 11:56 AM
mach1's Avatar
To the top
Old 02-17-2011, 12:37 PM
jmd
jmd's Avatar
Try a brake and clutch exchange place. 60 thou. is probably fine but verify.
Old 02-17-2011, 03:31 PM
SNLPerformance's Avatar
Depending on the lift and release of the pressure plate .060 may be HUGE.
Shoot me an email with more information and I'll help you out.
Steve@monsterclutches.com
