Clutch gets soft/soggy
99 z28. Stock clutch and master cylinder.
After I rag the car threw 1st and 2nd the clutch gets soggy/soft.
I heard that this is because of the master cylinder not returning fluid back fast enough.
Has anyone experienced this that can tell me for sure what needs to be done?
Anyway a permanant fix comes in a pricey little clutch master cyl but is a much better then facory one from Tick Performance.
But before you jump the gun start with the fluid in the clutch master, is it dirty or clear.
The clutch fluid was black as can be and somewhat thick. I sucked all the old fluid out and refilled the resovoir with new fluid, drove the car and sucked the fluid out and refilled it again. Although it helped for a minute it didn't completely take care of the issue. I was told by a local shop that doing this a few times (maybe 3 times a week this week and next) could possibly solve my problem. If that doesn't work then i'll go ahead and buy an master cylinder as that seems to be the main problem here.
The correct way would be to bleed the slave and get all the old fluid out of there... Altho when you purchase a new clutch cyl get the speed bleeder from Tick Performance. Makes bleeding it much easier the next time.
