Convert flange output to yoke T56?????
Has anyone on here converted a flange style trans T56 out of GTO/ Cadillac to a yoke style output??
Thanks
BobH
What a dumbasss I just went out in the garage and looked at the flange apparently it just slides out like a regular yoke, duhhhhhhhhh.
Now I'm sure about the caddy does it also just slide out???
Thanks
BobH
http://www.eecis.udel.edu/~davis/z28..._Fbody_T56.pdf
Although this speaks to the 32-spline upgrade, the conversion info is basically the same (and easier) when doing the CTSv conversion to a 27-spline GTO.
Thanks for the responses
Actually had one each cts-v and gto box. I'm putting the gto box in my 57 and thought the yoke was permannet like the caddy until i went back in the garage and popped out the goat flange
thanks
bobh
mike linkee no workie
thanks
bobh
I just double checked and it still worked for me. You have to click the link, cut&paste won't work.
http://www.eecis.udel.edu/~davis/z28..._Fbody_T56.pdf is the full link
