Clutch problems. Pls help!!
I have a 2000 trans am with t56 and any time im driving my car hard or shift over 5000 Rpms my clutch pedal sticks to the floor. Pls help.!
This is most likely a hydraulic issue associated with air in the system and/or the need for the drill mod to be performed. You can reference the sticky above (the third one from the top) which has tons of info relative to this. Ultimately you ought to try bleeding the system first though. I suggest the use of a Mighty-vac and bleeding from the valve off the slave on the bottom and the reservoir at the top. Let me know if you have any further questions and I will be happy to help.
