M6 MSD 2step
M6 MSD 2step
Wanted to know which wires should I cut/splice on the clutch safety switch to install the MSD 8733 2step? The 2 wires going into the switch are purple/white and a solid green. I'm not worried about having to use the clutch to start the car.
I used the clutch switch that controls the cruise control. Since it grounds to kill the cruise I just tapped in.
I believe it was the grey and blk wire on the white switch.
The switch in the middle and the harness on the left is what I have. Some cars may have the harness on the right.
