clutch has play when i first drive
Old 04-28-2011, 12:25 PM
bluethunder2k3's Avatar
Default clutch has play when i first drive
this started just before i put the car away this winter, and i just recently hauled it out. When the car is cold and i shift i only have about a half of a pedal, the first half is just a loose clutch pedal. But once the car is warmed up its fine, and it doesnt grind or seem to be slipping. car is a 99 t-56 with 69k on it. Anyone have any ideas?
Old 04-29-2011, 05:25 PM
SNLPerformance's Avatar
How does the fluid in the Clutch Master Cylinder look? Could be the seals are a little dry from sitting so long.
