shimming overlook
Old 05-14-2011, 05:45 AM
cfgioja's Avatar
Default shimming overlook
If u shim a spec clutch on an ls1 with the c5 two piece bell housing when not needed, will that cause a bleeding issue?
I installed onewhile forgetting to measure and now I get fluid while bleeding but my pedal never stiffens up?
Old 05-14-2011, 10:06 PM
Nmbr1GMfan's Avatar
The shim could keep the clutch from fully disengaging but the slave should work properly.
