Grind sound on stop
Grind sound on stop
I notice that if I am coming to a stop just before the car stops, the transmission will do a "grind" sound. It doesn't matter what gear it is, I thought it was 1st only, but it turns out as long as left in gear, just a moment before it stops it makes a grind and I see my speedo spike. If not in gear, there is no grind coming to a stop.
I'm going to change fluid tomorrow and see if it helps, wondering if I'm low on fluid and its just inertia of all the fluid going forward.
Anyone notice this happen?
I noticed the grind happening on slow maneuvers like trying to park. It looks like something is not right in there right now, but its intermittent. I can't replicate it by either coming to a stop or just moving it. Either way, it happens when its crawling is the best description...
Actually after more diagnocing, I noticed I have clutch drag. It'll move forward in 1st if I rev up to 4k+.
I tried adjusting my master, got to 18 turns on the master and still no difference. I actually got it so far its not engaging the clutch safety switch...
I backed it off to 13 turns, it lessened the grind making me think the grind on stop is clutch drag. Will make a new post for the new issue.
