sbc swap, what t56?
sbc swap, what t56?
I want to swap a sbc into my 4th gen, but i have a huge decision to make, and im not sure w3hich way to go with it.
i can buy an lt1 t56 and have it bolt up no problem, but I want a hydraulic TO bearing.
can i use a ls1 t56 with a lt1 bellhousing? I would rather not buy an adapter plate because im assuming I will have to shorten the driveshaft.. any suggestions?
2 bolts don't line up in the LT1 bell / LS1 face.
There's a limited amount of space for a hyd. TO brg. & a push clutch in the front of an LT1 face / bell (McLeod's first design for that app. was too deep for it but that's years ago) but that's a valid option.
One option is to drill & tap the 7th hole in the block for LS1 bell, shim the slave on an LS1 trans. and use a pop-out pinion starter ('88-96 Corvette) in case the bellhousing doesn't allow the starter you have.
I have a starter that can mount probably a thousand different ways, im pretty sure it should work, haha.
