Slave cylinder (hydraulic release bearing) for T56 Magnum...??
Old 06-01-2011, 12:28 AM
Dave-1970's Avatar
Default Slave cylinder (hydraulic release bearing) for T56 Magnum...??
The T56 magnum has a much beefier input shaft which means that a stock f-body slave won't have as much clearance as it would with a standard T56 input shaft. I've seen the one from Kiesler but they are super expensive (almost $400 and require all sorts of spacer plates etc... Kiesler's slave for T56 Magnum has bore measurement of 1.163''= 0.148'' total clearance (0.074'' on all sides of magnum input shaft). My f-body slave (bore) measures 1.070'' while the input shaft measures 1.015'', that is only 0.055'' total clearance. That leaves 0.0275'' on all sides of the input shaft...Kinda close... I am tempted to hone out some material on the GM slave to make a little more room. Anybody have any input on this??? Thanks!!!
Old 09-01-2011, 11:27 AM
foler's Avatar
which gm # purt number slave cylinder to buy for this tranny?
Old 06-13-2016, 09:37 AM
chuckd71's Avatar
What ever came of this? Would some very light dremel work be sufficient?
Quick Reply: Slave cylinder (hydraulic release bearing) for T56 Magnum...??
