T56 Question
Old 06-21-2011, 03:10 PM
Anderson0741's Avatar
Default T56 Question
Okay so I know that a corvette T56 wont fit in a Trans Am, but I found a T56 from a 1997-2004 Corvette, and my 5-6 gears went out on my Trans Am, would the internals be interchangeable?
Old 06-21-2011, 03:29 PM
Jeremy@RPMTransmissions's Avatar
No. The corvette trans has triple/double cone style blocking rings where as the F-body has Double/single. The gears won't interchange.
This question would also be better if put in the manual transmission section of the board. That is where all of the T56 guru's hang out
Old 06-21-2011, 03:53 PM
Ah this forum just confuses me haha, or it would be there. Would I be able to use parts from my T56 to get it to work with my car?
Old 06-23-2011, 04:56 PM
Zbinkley's Avatar
Take your tranny apart, 5/6 gear are just under the tail housing so you wont even have to totally disassemble it(I wouldn't if you just wanna get it going). Figure out whats wrong(synchro or gear) and order NEW parts. They aren't that expensive. Oh and download a service manual. <---they are everywhere, just ask google.
Old 06-24-2011, 07:36 AM
No problem. It takes a little bit to get used to the setup. You could make that trans work in your car but you would need a GTO main shaft and combine both the corvette and the f-body trans to make one. If you wanted to send them to us we could do the conversion for you for a very reasonable price.
Old 06-24-2011, 09:51 PM
Thanks I think Ill do that, but I would like to try it. Is the city your from called Anderson?
Quick Reply: T56 Question
