GTO T56 in a camaro
GTO T56 in a camaro
I am looking at putting an LS2/T56 from a GTO into my 01 camaro. Will the T56 work in an 01 camaro or will I need a T56 from an fbody? If it will work, will the fbody clutch master cylinder work with the LS2 slave? I will be using my 01 LS1/T56 camaro wiring harness and PCM.
While we are at it, anyone know if the GTO LS2 oil pan work in an fbody?
Thanks!
Thanks!
