ls1 bleeding help
ls1 bleeding help
II've been bleeding now for 4 weekends straight and im sick and tired of the bullshit hydraulics in the f body's Ta's. Does any one have a known working method of bleeding the slave. I've tried gravity bleed,old fashion crack the bleeder valve,miry vac n I still don't have the right pedal engagemen/disengagement. I've heard of the jmd method but don't quite understand it, is there a video of someone using that method.any ideas is very appreciated.
Have you noticed any changes in the reservoir fluid level? I assume you would have noted leaks so the Master is the most likely cause of this issue and it can bypass fluid internally without ever visually leaking.
No fluid level changes. I figured if there's a leak the resvoir level will decrease but the fluid level is always full. I did the drill mode but still not the right pedal engagment
