Stock clutch replacement
Hello, my LS1 vehicle is basically stock and i plan on keeping that way.
Do you guys know what a good, cheep clutch replacement would be? i know that sometimes autozone/oreily parts are just as good as GM parts but much cheaper.
also what about pressure plate and slave cylinder?
PS i tried and was unable to search for this answer, Thanks!
Autozone/duralast clutch, flywheel, and presure plate $400
Oreily/sachs clutch, flywheel and pressure plate, also $400
GM Performance LS6 flywheel, clutch, and presure plate $450 is this a real GM part? how do i know if a part is a real GM part? is any part that has 'GM' in the title a GM part or what?
LUK clutch only $75
SPEC clutch and pressure plate $300
Just Disk $270 (new GM parts.com)
LUK clutch only $75
Diamond PP and disk $400
Monster 11" clutch kit $800 do they have low-performance clutches? i could only find this 800 ft lbs kit?
From what I understand, all the stock replacements are the LS6 clutch. The guy I bought my car from had put an LUK in it and it's been in there 5 years going strong with 380rwhp.
Still holds good... knock on wood.
