LQ9- tr6060 clutch ??
Old 08-25-2011, 03:47 PM
69c4x11's Avatar
Default LQ9- tr6060 clutch ??
I have bought a 2010 Tr6060 from aCamaro, also the shifter,, I'm going to mate it to my 01 lq block and stroker crank,, What flywheel /clutch set-up do i need ?? Is there a difference in the LS1 clutch compared to the LS3 ?? help me out ?? Yes i'm having the shifter mover forward 3" to fit my hybid, just a little fab work to do this,, Clutch- flywheel ????????????????
Old 08-31-2011, 03:21 PM
69c4x11's Avatar
Hey, Surely, I'm missing something ??? Is there a diffrence i What do I need to mate up???n a LS1 clutch/flywheel, compared to an LS3 ??? I know the TR6060 is different,
Old 09-02-2011, 02:59 PM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
I see no reason why an LS7 clutch kit wouldn't work for you.
Andrew
Old 09-02-2011, 05:11 PM
jmd
jmd's Avatar
They have the same spline / o.d. of the input but run different deeper depth face-plate/bellhousing combination parts, the larger o.d. pilot and different length inputs and slave cylinders. As well, LS1 had flat flywheels across the board; LS2s went stepped as did the LS7.
Easy answer: get a clutch & flywheel for a 2010 Camaro.
Old 09-02-2011, 08:58 PM
69c4x11's Avatar
I'm bulding a 408, ls3 heads,eagle crank,diamond piston 12:1 , will a LS7 clutch flywheel handle it ??
Old 09-03-2011, 02:30 PM
Yes, if you don't drive like a douchebag...
Andrew
Quick Reply: LQ9- tr6060 clutch ??
