changing trans fluid
Old 08-30-2011, 10:05 AM
_Silver_'s Avatar
Default changing trans fluid
Changing my transmission fluid seems like its gonna be a pain in the ***. Does any one have some suggestions on ways to make it easier?
Old 08-30-2011, 11:30 AM
RedRallyeZ's Avatar
buy one of those $5 suction pumps at advance auto. made my life a lot easier, no need to even remove the shifter.
Old 08-30-2011, 01:37 PM
BALLSS's Avatar
if we are talking about a T56...they have a drain & fill plug.
You can but a pump for a few $ to fill from 1 qt fluid bottle to make it simpler
Old 09-15-2011, 12:20 PM
Grind's Avatar
Suppose a guy just put the transmission back in the car, but hasn't put the shifter back in. Can the guy full the transmission through the shifter, thereby avoiding buying said $5 pump and needing to get under car?
Old 09-15-2011, 12:28 PM
Deviant LS1's Avatar
If the shifter is off you can fill the transmission through there.
Old 09-15-2011, 12:30 PM
Grind's Avatar
Awesome! Thanks for the quick reply!
