Removing upper console?
Old 08-31-2011, 08:36 PM
T AM's Avatar
Default Removing upper console?
Yes, I searched, all I found was how to take out the entire console. I just want to remove the upper part. I know I need to disconnect the ash tray light and the cig lighter, but after that, do I just pry up on the upper portion with a flat blade screw driver or something to remove it? Thanks
Old 08-31-2011, 08:40 PM
J LT1 TA's Avatar
lift up the console lid and there is two bolts, take them out. and use a little force and it will pop right out, the rest is held in by clips.
Old 08-31-2011, 08:46 PM
Lxtasy1's Avatar
2 7mm bolts under the little coin holder in the main arm rest compartment.Remove your shifter **** and as stated above.Its like a 5 minute job.
Old 09-01-2011, 08:14 PM
T AM's Avatar
Thanks!
Old 09-01-2011, 11:00 PM
got-a-ls1's Avatar
5 minutes if you drink a beer... lol
