Will LS3 Spec dual clutch work with T56?
Old 09-10-2011, 01:40 PM
LSxChevelle's Avatar
Default Will LS3 Spec dual clutch work with T56?
I'm buying a LS3 shortblock and can buy his 3k mile Super Twin Spec setup for 650 or maybe less. If I happen to buy a T56 due to cost will the clutch work? Or are they different?
Thanks,
Jason
Old 09-12-2011, 02:46 PM
SPEC-01's Avatar
This should be fine. Just make sure you measure to determine the need, or lack thereof, for a shim.
Quick Reply: Will LS3 Spec dual clutch work with T56?
