Master cylinder question
Old 09-20-2011, 05:15 PM
02 Camaro's Avatar
Default Master cylinder question
Im doing an A4 to T56 convertion and i was wondering if the is a hole for the master already cut out or if im going to have to cut a new one....
And what kind of fluid does the master cylinder need and how much
Thanks
Old 09-20-2011, 05:24 PM
MR_M's Avatar
Auto cars do not have the hole, you will need to cut one. And regular dot 3 brake fluid is just fine for the clutch fluid.
Edit: As far as the actual amount of fluid... I couldn't tell ya as you will potentially lose a good amount through the bleeding process. At least buy a larger bottle (like a quart instead of the pint) as that will most likely be enough.
