Possible to use a 153 tooth flywheel on LS?
I am doing a swap into a car with a small trans and bellhousing area. Is it possible to use the small 153 tooth flywheel? I know the old style bellhousing will bolt onto the new engine but what to use for a starter? The trans used will have the standard 'old GM' pattern.
Sure, but you provided little detail.
The only part of an old "Muncie" bell that's bigger is the starter pocket.
https://ls1tech.com/forums/conversio...-flywheel.html
Post more and add detail.
More detail
I have seen pictures of both bells side by side and the 153 tooth version is much smaller in diameter. I don't have anything at this time and am basically collecting information before the swap starts. I have a PM that says the big bell (621?) does not fit in the car I am dealing with.
Using the smaller bell would save a ton of rework that I don't want to do and I don't need the giant clutch for a stock 5.3 in a light car with little tires.
I don't know. I have not started the swap - I know the T56 doesn't fit without butchering the car otherwise I would just use one. Like I mentioned I have a PM that says the big bell does not fit so I would like to use the small one.
Bump - anyone know anything about this
I have found a place to make a nice light 153 tooth LS flywheel and of course the PP and disk is not a problem. The problem is the starter. I found a place in Australia that makes a starter for 'their' conversion 153 tooth flywheel used in a Land Rover LS engine swap but they have not returned my email and I don't feel like making an expensive long distance call in the middle of the night to see if this thing will work for me. If it does I should be able to buy it from Advance Adapters here in California.
Steve
Steve
