Whats needed to run t56 without it being hydralic?
Old 10-04-2011, 08:55 PM
93hatch's Avatar
Default Whats needed to run t56 without it being hydralic?
This is for my mustang, dont want to run a slave cylinder and what not, just a cable and quick release quadrant. Ton of people run ford based t56s just curious if I can do the same, will be bolted up to an lq4 if thats relevant
Old 10-04-2011, 09:40 PM
jmd
jmd's Avatar
Sounds a lot like what I did to run mechanical linkage and third gen T5 V8 clutch with a '95 LT1 T56.
Get a Ford front adapter plate, change the TO brg. tube to aftermarket billet, bolt up an LS scattershield and add the needed provisions for the cable housing and fork. Figure out the details as you go along.
Old 10-07-2011, 12:02 AM
eabcobra's Avatar
I think quicktime bellhousing makes a bellhousing that will work.
Old 10-08-2011, 12:26 PM
93hatch's Avatar
then just run a ford fork?
Quick Reply: Whats needed to run t56 without it being hydralic?
