Clutch chatter
Clutch chatter
Im getting clutch chatter at around 2k-2500 when i ease into it. I had it actually slip once. If I drop a gear and lay into it nothing even power shifting. Ive only been noticing it in the last month, its not my dd so not much driving. I have changed to a different 9in rear and strange moly DS. Gears only changed from 4.11 to 3.89. Didnt know if that had something to do with it. I figured maybe becasue it has to do with more load or load is so low the clutch is locking up full at those rpm's but doesnt sound right. Any help would be great, thanks. Oh and spec stage three with light weight steel flywheel.
I think I started a thread with the same issue. When accelaration from around 2K or so it bucks and jerks until I climb to around 3K or 3200RPM. Under full throttle it is totally fine just light throttle and low RPMs it jerks.
