Tail Shaft Seal for T56?
So I have my T56 out and figured I would replace the seal, went online ordered one. Doesnt appear to be the same as whats on it. I have replaced it once, but it appears to still leak.
The one I just bought is part number 361165. Does anyone know the correct part number.
You can see the difference between the 2, one has a lip on it to go over the driveshaft.
The dust boot isn't going to solve a sealing issue between the yoke and seal.
How is the driveshaft vertical play when all installed?
361165 is the seal only style.
Try 10117848 or 12530278 at a dealer or napa NOS 14635 or NOS 14569 for the uncircumcised seal. Don't quote me on the Napa.
Will the seal only style work? Or do i need the dust boot? Im sure there is alot fo play, almost 87k on the car, stock driveshaft and rear. Will be upgraded probably next year.
