What size hydraulic line
Old 01-09-2012, 09:01 AM
stewdy1's Avatar
Default What size hydraulic line
Ok I have a ls1/t56 swapped mustang(real original I know) and I'm using 4an line, is this to big of a line, I know the tick comes with 3an
Old 01-09-2012, 03:05 PM
SNLPerformance's Avatar
We typically run a 3an on swaps... are you having issues with the clutch/hydraulics?
Old 01-09-2012, 06:16 PM
stewdy1's Avatar
Yea seems like the clutch isn't fully disengaging till I'm all the way to the floor and once in gear the car starts moving when pedal is inch off the floor, I'm thinking maybe the line being too big is not letting pressure build up properly.
I just order new clutch and flywheel so I'm gonna measure and make sure I have the proper space and if so install it but if problem persist I'm gonna change to number 3 line and see if that helps
Quick Reply: What size hydraulic line
