stock 2000 ram air
stock 2000 ram air
i have a stock ram air and the clutch pedal is going to the floor and not returning no clutch at all any suggestions?? could it be the master cylinder or slave cylinder?? t56 stock tranny with 40,000 miles
Have you lost any fluid? Is there fluid dripping out of the bell housing or leaking into the floorboard or fluid under the brake booster? If neither are leaking than it is hard to tell whether the master cylinder or slave cylinder have failed internally. Replacing the master first would be easier as you have to drop the transmission to change the slave.
