Redline heavy shock fluid
Has anyone used this in the T56? I am looking to protect the Tick built T-56 I have heard great reviews on the same oil in rear ends, But I am worried about the damaging the synro assemblies.
If anyone has used this with success I would like to hear about it
Thanks
assuming that this is the sales pitch
Red Line heavy ShockProof gear oil is a unique lubricant containing a suspension of solid microscopic particles as an extreme pressure agent. It provides a unique solid dispersion, which cushions gear teeth to help prevent tooth breakage and allows the use of lower viscosities. The viscosity characteristics allow the lubricant to resist throw-off and provide a film thickness similar to a 75W250 grade, while providing the same low fluid friction as an SAE 75W90. This gear oil is recommended for heavily loaded racing differentials and transmissions, off-road racing, and problem gearboxes.
Thanks
